X440-G2-24p-10GE4 High Fan speed
Marcel1
I have 2 of these Switches stacked on eachother.
The top one is more under load most of the time and is currently running at 89F(31C)
All 4 fans are between 8000RPM and 9000 RPM
Why is it that they would be spinning at that rate? and why only this one switch?
Would it be due to the temp, or higher usage?
the Switch below this one is noisy at all. and is also running at 87F(30C)
Fan speed: 2160RPM
Any feedback would be greatly appreciated.
X440-G2-24p-10GE4
version 21.1.1.4 21.1.1.4
Thanks
1 ACCEPTED SOLUTION
10 REPLIES 10
Narayanan__Kart
Hi Marcel,
Do you have any impact like too noisy or over heat on that particular switch?
Otherwise it could be a bug. Please check the below article:
https://gtacknowledge.extremenetworks.com/articles/Solution/Wrong-temperature-output-and-fan-behavio...
Can you please provide us the below output from the stack:
show temperature
show fan
show log
debug hal show platform platforminfo
Regards,
Karthikeyan
