01-20-2020 11:53 PM
Hi everyone,
So I’m a new user here in the EW forums. So recently I started a new job and inherited the Extreme Wireless system. The downside is, there’s no documentation (long story) and I’m having an issue with a X430 8P.
Only a few ports work on the X430P (port 5, 8, and 10). I’ve checked all the other ports are enabled (they’re Enabled and Ready) but yet nothing will work to get them to actually work. I’ve added them to the VLAN(s) and still nothing.
This particular X430 8P feeds into a Extreme X440G2-48p-10G4 in the basement which is the MDF. Is there something I have to do on the X440G to get this to work right?
If anyone can please help I would be extremely (no pun intended) grateful.
Solved! Go to Solution.
02-04-2020 02:52 PM
Hey Kev,
Just to come back around with this. I tested everything and couldn’t find anything wrong with Port 1 in the corresponding log. So anything else I could try? TY.
02-04-2020 02:52 PM
Hey Kev,
01-29-2020 05:35 PM
Noted.Thanks again Kevin.
01-29-2020 05:33 PM
If correct, during the diagnostic process no port works. You have an approximate time of 15 minutes for that switch model,
01-29-2020 05:30 PM
Hey Kevin,
So by, ‘cut of the network services’, you mean that during the operation all of the ports will go down, right? If so I can run that early morning before anyone gets into the room. Thanks!
