Source Based Routing
Jason_Weems
New Contributor II
I have multiple routes to a particular network, I would like to route a particular local network over a certain link, while the rest of the local networks to that remote network over the normal routes. Is there a source based routing solution I can use with my x460s running XOS 15.2.1.5 ?
12 REPLIES 12
Chew_Choon_Chon
Tried PBR (both redirect and redirect-name) and it did not work for me. Followed exactly same commands as concept guide but still does not go to wanted next hop but used default routing table instead. Any one able to get source ip based routing with PBR working on XOS 15.6?
Jason_Weems
New Contributor II
Well actually I have, and it didn't seem to work. I am looking at a static routing solution. The PBR seem to work with the routing protocols.
Cibulka__Leandr
New Contributor II
Have you tried PBR?
