OOB Routing: Accessing OOB from different subnet
schuert
New Contributor III
Hi Guys!
A few days ago i updated our vsp 7254 to VOSS Version 8.2. The new version implemented some changes for the management-interfaces/IPs according to:
Our OOB is segmented into different subnets. if im trying to connect from the same subnet the oob-ip belongs to, i can successfully reach the system but i can’t ssh or even ping the oob-ip from the other subnets.
i created the static routes for the different subnets with:
enable
conf t
mgmt oob
ip route 172.28.12.0/24 next-hop 172.28.15.1
ip route 172.28.13.0/24 next-hop 172.28.15.1
ip route 172.28.14.0/24 next-hop 172.28.15.1
exit
the oob-interface has the ip 172.28.15.5/24. how come the interface wont route? is this intentionally?
Best regards,
schuert
1 ACCEPTED SOLUTION
schuert
New Contributor III
found the error. i pinged and checked ssh from a connected exos switch and forgot to define the from ip, which in turn caused the switch to use its transport subnet ip to ping, which isn’t defined via static route on the vsp.
thanks for helping me to figure out my mistake
8 REPLIES 8
EXTR_Paul
@schuert TTBOMK all three interface types will work at the same time.
OoB, L2, CLIP.
Miguel-Angel_RO
Valued Contributor II
schuert,
Why dont you simply add a default route to the oob mgmt?:
enable
conf t
mgmt oob
ip address 172.28.15.5/24
ip route 0.0.0.0/0 next-hop 172.28.15.1
enable
exit
There are some characteristics to keep in mind:
Mig
schuert
New Contributor III
the oob-interface was enabled already. i can reach and connect the ip via a system in the same subnet but not from different subnets. other devices in these subnet can successfully route via the GW to the 3 other oob-nets, so this can only be caused by a routing-problem on the vsp.
additionally im using a clip in vrf0 for inbound management, maybe using two kinds of mgmt-interfaces is not supported?
#show mgmt interface
Command Execution Time: Wed Jan 06 23:16:05 2021 UTC
Mgmt Interface Information
INST DESCR TYPE ADMIN VLAN PORT VRF PHYSICAL
1 Mgmt-oob1 OOB enable - oob - 94:9b:2c:a2:18:81
3 Mgmt-clip CLIP enable - - GlobalRouter aa:bb:cc:dd:ee:01
2 out of 2 Total Num of mgmt interfaces displayed
#show mgmt ip
Command Execution Time: Wed Jan 06 23:15:26 2021 UTC
Mgmt IP Addresses
INST DESCR IPV4 TYPE (ORIGIN)
1 oob1 172.28.15.5/24 Manual
3 clip 172.28.64.23/32 Manual
2 out of 2 Total Num of dynamic addresses displayed
#show mgmt ip route
Command Execution Time: Wed Jan 06 23:15:02 2021 UTC
Mgmt IPv4 Route Information - Table main
DEST/MASK NEXTHOP METRIC INTERFACE TYPE
0.0.0.0/0 0.0.0.0 100 Mgmt-clip INTERNAL
172.28.12.0/24 172.28.15.1 300 Mgmt-oob1 STATIC
172.28.13.0/24 172.28.15.1 300 Mgmt-oob1 STATIC
172.28.14.0/24 172.28.15.1 300 Mgmt-oob1 STATIC
172.28.15.0/24 0.0.0.0 1 Mgmt-oob1 LOCAL
172.28.64.23/32 0.0.0.0 1 Mgmt-clip LOCAL
6 out of 6 Total Num of mgmt ip route displayed
EXTR_Paul
Here is a config example I have used.
mgmt oob
ip address 20.20.20.200/24
ip route 0.0.0.0/0 next-hop 20.20.20.1 weight 300
enable /////// Not sure if this is required.
exit
