Extreme XCC VE6120 Interface Mngt
Mdemiljo
Hi
I have a client with Extreme VE6120 wireless controller and the client's local IT unchecked the mngt tick on the interface settings. Now we can't log into the web interface of the controller. Daily backups of the controller config was done, but how do I restore the config backup from CLI, or how do I reset the interface settings via CLI
1 REPLY 1
StephanH
Valued Contributor III
Hello,
you can enable management again via CLI:
  • Login via SSH or console
  • Type "topology"
  • Type "show" (look for the regarding interface)
  • Type the interface name
  • Type "l3"
  • Type "mgmt enable"
  • Type "apply"
=> No the inteface should be reachable via HTTPS again.
Regards Stephan
