increasing wifi speed using AP410c
‎03-27-2024 09:23 AM
HI, we are new to Extreme Network product. we have just installed new AP410c APs in our new office and we have noticed that client connect to speed of 286/286 (Mbps)
is there a way to increade it?
additional info:
-protocol : Wi-Fi 6 (802.11ax)
-Wifi Frequency: 5 GHz
-latest windows drivers
thanks for your help
Stefano
‎03-28-2024 06:01 AM
Stefano, the connection speed between a client and the AP will vary, based upon connection conditions. You can configure the AP to have a certain maximum possible connection speed but that does guarantee that this speed will be used.
‎03-28-2024 06:00 AM - edited ‎04-02-2024 05:33 AM
Hello @svettori,
This article will give you an idea of what speeds to expect although 4x4:4 spacial stream data is not included.
https://extreme-networks.my.site.com/ExtrArticleDetail?an=000116378
Recommendations:
1 - Create a new radio profile so that you may make changes to the parameters therein
2 - Enable DFS channels
3 - Change channel width to 40Mhz and if you don't have too many APs you can even test with 80MHz channel width
4 - Enable OFDMA in both directions. In default profile this is not enabled.
Test to see if speeds increase.
BR,
Chris
