NAC with third Party wireless solution
Andre_Brits_Kan
Contributor II
We are in the process of deploying a Extreme NAC solution with a third part wifi Solution (Fortinet Enterprise - Old Meru). The solution requires us to return specific radius attributes. When I add the "switch" as a NAC client I can select from the predefined radius attribute list or create a new one. Some of the radius attributes refer to %custom% attributes. For example the client wants to return the custom attribute only when a andriod device connects to the system and the attribute needs to be "name-vlanID" ie "staff-112" Where on the rule do you specific the custom attribute to be returned?
2 REPLIES 2
Andre_Brits_Kan
Contributor II
Thx Ryan just what I needed.....
Ryan_Yacobucci
Hello Andre,
Check this article out:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-NAC-for-custom-radius-att...
The profile that is assigned to the rule has a policy mapping, inside this policy mapping you can use the Custom fields to put in attributes.
Thanks
-Ryan
