07-14-2023 05:46 AM
Hi all,
I have 2 APs at home. the primary one acting as mesh portal (ap250) is wired connected and broadcasts only 5G wifi and the second AP which is meshed (ap230) on the 5g interface (wifi1) and it's set on Backhaul Mesh Link and Client Access mode. (dual mode)
everything works well however I've noticed I am not able to connect to anything else then 20MHz.
I need more bandwith and I am trying to force the usage of 40MHz, however i don't know how. (from the CLI.)
any suggestions?
thank you
08-03-2023 05:15 AM
yes. I am using a dedicated channel I decided after i scanned the area.
07-17-2023 05:25 AM
Hello Mihai,
Is this what you are looking for?
#radio profile <5GHz radio profile name> channel-width 40
BR,
