10.41.10 - dashboard, low link speed shows wrong value
Ronald_Dvorak
Honored Contributor
I've just upgraded a customer controller from 10.41.05 to 10.41.10 and now the dashboard show 213 APs with low link speed = all APs.
I've checked one switch with about 10 APs and the "show port no" result is that all the AP ports are actual speed/duplex of 1000/full.
Tried a reboot of 10 APs but no change.
If you click on the low link speed counter the pop-up list only 3 APs - not sure whether that is the max that is shown in this window.
I'd see the same result on my lab controller - even there are only 8 out of 12 with low link speed - I know that is also not correct.
Is that a known issue !?
-Ron
6 REPLIES 6
Ronald_Dvorak
Honored Contributor
Thanks Craig..... so more overtime to upgrade to 10.41.11 🙂
KR,
Ron
Craig_Guilmette
Hello Ron
Yes it is a known issue and fixed already by Engineering and will be in the 10.41.11 release.
