‎10-25-2018 10:11 AM
‎10-25-2018 10:20 AM
AnswerNo, those two features should not be used together. Sites is meant for APs that might lose connectivity to the controller, while the high availability feature is based on the use-case that there will always be a connection to the controller (pair).
When these features are used together there can be incorrect behavior when roaming on APs in sites-mode or disconnects, so it should be decided to either use 2 controllers in a HA pair, or APs being configured for sites, but not both.First time that I've heard that I shouldn't use this two functions together..... I don't buy it 
