3935i LACP with same switch possible ?
Pascal_Lurquin
New Contributor II
We are using 3935i APs
They are connected to only one port : I saw the LOW mode in the log
We would like to use it with performance: we have to use TWO ethernet ports
Is it possible with only one POE switch X440-48P
Thanks
7 REPLIES 7
Ronald_Dvorak
Honored Contributor
In case the KB article is correct and also is valid for the AP3935i then just turn PoE off on one switch port and configure the LAG and that should work.
Narayanan__Kart
Hi Pascal,
If the Ethernet ports of the AP are connected to separate switches in a stack, then the switches in the stack can provide both POE and LAG functionality simultaneously to the AP.
Regards,
Karthikeyan
Narayanan__Kart
Hi Pascal,
I dont think we can connect both LAN ports on the same switch. Please check the below article for more information:
https://gtacknowledge.extremenetworks.com/articles/Solution/AP3825-cannot-be-powered-when-connecting...
Regards,
Karthikeyan
