AP3805i connect only at 100 Mb at X440G2-48p-10G4 switch
JohanHendrikx
Contributor II
I have more than 50 AP 3805i connected at X440G2-24p-10G4 and X440G2-48p-10G4 switches.
One AP connect with 100 mb instead of 1Gb.
Port settting on the switch is auto. Also at the AP.
I noticed that the interface setting on the AP is 10 or 100 Mb and not 1Gb??.
I already cleared the config of the AP but it stays 100 Mb
Other AP’s connect with 1Gb.
Johan Hendrik System Architect Audax
13 REPLIES 13
Aman
New Contributor II
i don't think it will work, bcz all remaining APs except this AP are working on gig link.
Aman
New Contributor II
Hi johan,
did you reset the AP?
from where you see your AP is showing low link speed?
Ronald_Dvorak
Honored Contributor
I agree, check the cabling...
Aman
New Contributor II
It could be due to cable fault also!!
please check once and do the factory default AP.
