Extreme Wireless Controller Splash Page - No Redirrection Problem
Grzegorz_Niemi1
New Contributor II
Dear All,
I have encountered a problem with configuration of splash page. I have made two roles, before and after registration. Unfortunately in unregistered role controller does not redirect the traffic. When I type an address of my splash page in web there is only something like this (Below) but i cannot accept anything so there is no connection to the internet.
be4a1d672b5a4c4ba9cd550f374b0c0b_RackMultipart20170821-57566-8ziugm-Splash_Direct_inline.png
My rules on the controller looks like this:
be4a1d672b5a4c4ba9cd550f374b0c0b_RackMultipart20170821-45599-1h26ia3-Wifi_Roles_inline.png
172.16.4.10 is the address of my splash page on the controller. Is there something wrong with these rules?
7 REPLIES 7
Grzegorz_Niemi1
New Contributor II
Thank you all for help. The problem laid in:
https://gtacknowledge.extremenetworks.com/articles/Solution/Clients-are-not-redirected-to-the-Guest-...
Here are politics which worked for me:
Doug
Grzegorz,
Were you able to get this working?
Thanks,
Doug
Doug Hyde
Director, Technical Support / Extreme Networks
Ronald_Dvorak
Honored Contributor
I think the role isn"t correct - here a example of mine, the 172.24.25.253 is the IP of the controller/portal in the guest topology so replace it with your controller/portal/topology IP.
Add the other rules exactly like below, the in/out is very important so make sure it's configured as below.
aa42c678f6ac4f6382d9d25dfe049135_RackMultipart20170822-48819-k064cc-EWC_guest_role_inline.png
Doug
DNS is resolving correctly? If that's the case I would contact the GTAC so someone can take a look at all your settings. This should work as it's a standard function with our controllers.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-contact-Extreme-Networks-Global-Tec...
Doug Hyde
