Print from wireless segment to wired segment is not working
juan_romero
New Contributor II
I have a printer in a wired segment with this ip 10.106.2.240/24 and my wireless segment is 10.106.3.0/24 but I can not print, ipforwarding is enabled in both vlans and both are reachable by ping. I have an x250e switch. and AP's are 3825i. Any idea?
3 REPLIES 3
juan_romero
New Contributor II
It“s locally bridged. Now I can print but can not scan :S... I did enable "multicast bridging"
Ronald_Dvorak
Honored Contributor
Could it be that the print service is working via multicast - that is disabled per default in the WLAN topology.
GUI > VNS > Topologies > select the Topology > select the multicast filters tab
You'd try it out and enable "multicast bridging" and add the "all multicast" + wireless replication.
I had the same issue with my Osram Lightfy (home automation) and with Apple TV.
Paul_Russo
Hey Juan
Is the wireless tunneled to controller or locally bridged?
Thanks
P
