samsung galaxy j7 wireless connecting problem
Mikaeil_Beigpou
New Contributor II
hi
please help me to solve this problem :
samsung galaxy j7 mobile have a problem to connect access point ap3825i
thanks
20 REPLIES 20
Ronald_Dvorak
Honored Contributor
I give you the GTAC answer... upgrade to latest version 10.11.05.
Mikaeil_Beigpou
New Contributor II
hi
vesion is 6.0.1
Jacob__Praveen
Mikhail,
What is the Android version? Do you know the command to run a tail on the AP that you are trying to connect to and do a "grep" for the Samsung device's mac address?
Thanks
Mikaeil_Beigpou
New Contributor II
hi
donot able to connect any other ssid.
thanks
Bharathiraja__S
Hi Mikaeil,
Let us know the client status in report and logs ?
if you connect any other SSID or wireless connection , are you able to connect ?
Thanks,
Suresh.B
