Here are my suggestions based on a LOT of TAC cases, some best practices from guys like Doug and Jason etc (very smart guys from the GTAC):
Only listing changes --
For all the APs
DTIM: 2
Dynamic Channel Selection: Monitor Mode!!!!
Protection Mode: Auto
Now, I would go through all of your radios and select Auto for the channel and save (with ATPC turned on). Let it go for a few min and when the AP has settled on a channel, disable ATPC. The idea of ATPC is to fill in dead areas of an AP in the surrounding area dies (boost the dB of the radio and fill in the gap). These days, I believe people try to have at least 2 or 3 APs in the area with great-good signal strength so if one goes out, there is another to hop to. When ATPC is on, any sort of interference or noise the AP is hearing may cause it to adjust its radios power, this could then cause all of the other APs to start adjusting their radios and you cause a ripple that can cause performance problems. Ideally, you will have great alerting so when an AP does fail, you can make some settings changes yourself, thus keeping in control and not causing any strange behavior.
Also, depending on how dense of a deployment you have, you may want to kick the min basic rate up to 12 or even 24 Mbps, but that is dependent on your deployment.
Also, why aren't you using 40 MHz channels on 5 Ghz? Conserving channel space?
