Voip problem 3825i
Voip problem 3825i
Luis_Mendes
Contributor
The customer have the solution voip with openstage WL3 wireless phone. The customer have more than 300 APs 3715i. With this APs the calls running fine. But when the roaming to any ap 3825 the calls have trouble. The calls have "cuts" and is not possible the talk. The firmware is 9.25 and the controller has a 5210
17 REPLIES 17
Hi.
No.. Never working with aps 3825. The customer has the solution more than one year.
The version of controller is 9.21.05
- The version of wl3 is (5.1.30) or (3.5.12) - The same problem on both versions
- The customer utilize only 5Ghz. The channels are NON-DFS (Brazil)
- PSK (WPA or WPA2).
Jeremy_Gibbs
Contributor
9.25? Or 9.15?... Anyway, we also have issues roaming between 3825 APs. I believe there is a new version coming out that should fix some of these issues. Just not sure when but I am assuming somewhat soon.
9.21.05
