flash mount at any controller and i see filese when restart controller flash unmount at one of the controller and other controller donot have any problem.
OK so you have 2 controller with v10.31.03 and 1 has a problem with the flash card.
What happens if you put the flash that doesn't work in the other controller - does it work or not ?
That would tell us whether it's a controller or flash issue.
