Wireless Firmware 10.x
Andre_Brits_Kan
Contributor II
Hi Do we have a release date for the new version 10 firmware for the wireless appliances? Thx Andre
31 REPLIES 31
What if I need to coexist 36xx with 39xx? meaning in the same location 3610's will be within range of 39xx, I assume we can setup a mobility domain, but will that cause any issues? Will roaming work?
One controller for the "old" APs and one controller for the rest.
Andreas_Barth
This is really a disappoiting decission from ExtremeNetworks and forces us to think about our strategy for WLAN environment from Extreme in future.
William_Aguilar
Yes, V10 does not support the 2600 nor 3600 Series. As I mentioned a few weeks ago you have a couple of options to expand your 2600/3600 network using 3700 or 3800 with V9.21 or you can work with one of our Partners and/or Extreme Sales representative to upgrade your legacy platforms to one of the newer platforms including the new 3900 Series Wave 2 APs.
n_n__n_n_
So software version 10.01.01.0129 is now available. I have the support contract, I can request the licenses for my C4110 controllers but I cannot use them because of the AP36xx devices:
Legacy AP26XX, AP36XX, AP4102 Series access points are not supported with V10.01 or later, however, these legacy APs will continue to be supported in maintenance mode only with V9.21 until they reach End-of-Support.
The decision to drop AP36xx devices in V.10 is final, right?
