01-29-2021 01:35 PM
I'm probably missing something but I cannot find LED indicator placement on new APs (310/410). In the installation and quick reference guides is only a table with colour description and "The LED indicators are located on the front face of the access point but are not visibly marked.” note. But which LED is which ???
Regards,
Mike
Solved! Go to Solution.
01-29-2021 03:04 PM
Hello Mike,
This may help:
https://extremeportal.force.com/ExtrArticleDetail?an=000084323
Thank you
01-29-2021 03:12 PM
That's exactly what I was looking for. Thank you - there is one thing missing, no ? Both AP4xx and AP5xx have 3 radios and the article shows only two (that means it's for AP3xx)
01-29-2021 03:04 PM
Hello Mike,
This may help:
Thank you
