AP310/410/i/e LED description
MichalK
New Contributor III
I'm probably missing something but I cannot find LED indicator placement on new APs (310/410). In the installation and quick reference guides is only a table with colour description and "The LED indicators are located on the front face of the access point but are not visibly marked.” note. But which LED is which ???
Regards,
Mike
1 ACCEPTED SOLUTION
Christoph_S
6 REPLIES 6
Christoph_S
Hello Michal,
Just tested, looks like VC status. The LED was blinking green under these conditions:
 virtual-controller
 no rf-domain-manager capable
Will modify article accordingly.
Thank you,
Chris
Christoph S.
MichalK
New Contributor III
@Christoph S. there is another thing missing in description: AP Status LED Green blinking - AP is Virtual Controller (or RF domain manager?)
MichalK
New Contributor III
https://documentation.extremenetworks.com/wireless/QRG/AP410ie_QuickRef.pdf?_ga=2.132958861.26442445...
There are 3 radios and Bluetooth (as Radio 4 in that case?) mentioned. Radio 3 is usually sensor
Christoph_S
Hello Mike,
1 - 2.4 GHz radio
2 - 5 GHz radio
3 - Sensor
Of course you can have Radio Modes SSR, but 3rd radio can’t be either 2.4 or 5 GHz.
Rgds,
Christoph S.
