01-29-2021 01:35 PM
I'm probably missing something but I cannot find LED indicator placement on new APs (310/410). In the installation and quick reference guides is only a table with colour description and "The LED indicators are located on the front face of the access point but are not visibly marked.” note. But which LED is which ???
Regards,
Mike
Solved! Go to Solution.
01-29-2021 03:04 PM
Hello Mike,
This may help:
https://extremeportal.force.com/ExtrArticleDetail?an=000084323
Thank you
02-10-2021 04:23 PM
Hello Michal,
Just tested, looks like VC status. The LED was blinking green under these conditions:
virtual-controller
no rf-domain-manager capable
Will modify article accordingly.
Thank you,
Chris
02-10-2021 02:58 PM
01-29-2021 03:57 PM
There are 3 radios and Bluetooth (as Radio 4 in that case?) mentioned. Radio 3 is usually sensor
01-29-2021 03:41 PM
Hello Mike,
1 - 2.4 GHz radio
2 - 5 GHz radio
3 - Sensor
Of course you can have Radio Modes SSR, but 3rd radio can’t be either 2.4 or 5 GHz.
Rgds,
