‎05-08-2018 07:30 AM
Hello,
I woud like to update/upgrade our Wing AP7522 APs from 5.8.6.9 to 5.9.1.1.
I using the express UI.
When I update the virtual controller, only this one will be upgraded after the progress. The other three will not.
I have tried several options:
1. I tried upgrade the VC (this should be the standard way, right?)
2. I tried to downgrade to 5.8.6.0. first. I thought it might still be the same bug. please refer: https://extremeportal.force.com/ExtrArticleDetail?an=000081096
3. I tried upgrade the attached APs over its own Webinterface. When I do this, the AP will startup with the new Firmware then goes down by itself and startup next with the old firmware.
What am I doing wrong? Thank you for your help in advance
‎05-08-2018 09:43 AM
‎05-08-2018 08:30 AM
‎05-08-2018 08:17 AM
