ExtremeWireless WiNG AP 7632 throughput?
‎05-24-2018 02:46 PM
May I know what is the throughput of WiNG AP 7632 in 2.4 & 5 GHz radios
8 REPLIES 8
‎05-24-2018 04:04 PM
Hello Prabhu,
Question 1: See the data rate section of the AP7632 data sheet.
Data Rates Supported 802.11b/g: 1,2,5.5,11,6,9,12,18,24,36,48 and 54 Mbps; 802.11a: 6,9,12,18,24,36,48, and 54 Mbps; 802.11n: MCS 0-15 up to 300 Mbps; 802.11ac on 2G VHT MCS0-9 up to 400Mbps, 802.11ac on 5G: VHT MCS 0-9 up to 867 Mbps
Question 2: The AP7632 can manage up to 64 like model APs (AP76XX).
I think he is referencing notation in the release notes that is out of date for older hardware like AP65xx: " WiNG 5 lets you build a controller-less solution of up to 25 access points for autonomous sites, ".
AP7622 is scaled for 64 APs in virtual controller mode.
Hi Andre,
Where you got this info from?
From what I know entire 76xx is scaled for 64 APs in virtual controller mode (same as 75xx without 7502).
Kind regards,
Tomasz
Kind regards,
Tomasz
No, AP7632 only can manage 25 APs
