How to do Bandwidth allocation per client or SSID in Extreme WiNG?
Carlo_Alviar1
Im currently configuring AP-8533 and im using one of the unit as a virtual controller. is there by any chance we could do the bandwidth allocation in this setup? where we could only allocate certain bandwidth per client or SSID.
1 REPLY 1
ckelly
Carlo, yes. The WiNG software does provide functionality that allows you to limit bandwidth either for an entire WLAN or per user on each WLAN. You can find these options in:
Configuration->Wireless-> WLAN QoS Policy->(QoS Policy)->Rate Limit Tab
You'll see in this tab that it's broken up into top and bottom sections.
The top half (left and right) are for rate limiting options for an entire WLAN. (upstream and downstream)
The bottom half (left and right) are for rate limiting options for each wireless client for upstream and downstream.
Once the WLAN QoS Policy is setup, you then apply the Policy as part of a WLAN's configuration.
Go into a WLAN and in the first section "Basic Configuration" you'll see a dropdown for "QoS Policy" where you can then select the WLAN QoS Policy that you created.
