Is there compatibility between Extreme Networks and Ubiquiti?
mario123na
Hi everyone
Could you help me? I need to know if AP7632 is compatible with US-8-150W Ubiquiti that they already have in their locations, would you have problems with POE power? or with the traffic to administer the AP? thanks so much
1 ACCEPTED SOLUTION
ckelly
It says that it has 802.3af/at ports, so simply based on that alone, it *should* be able to power the 7632 w/o issue.
2 REPLIES 2
Tuan_Nguyen1
You can use it normally. All POE standard AT use OK
ckelly
