Management capacity of WiNG Virtual controller
‎12-13-2017 02:26 PM
Hi community,
Could someone let me know the management capacity of a WiNG AP (virtual controller) such as max concurrent clients, user entry, WLAN,...like a real controller.
Thanks so much.
Thanks so much.
12 REPLIES 12
‎12-15-2017 03:48 PM
Thank you so much Aviv. Can I get the limitation of Captive portal database of entire wifi system when using Virtual controller mode with internal Radius server?
Hello,
Check here with CLI for limitations:
more system:/proc/dataplane/limits
Otherwise your limit is the RAM memory.
Regards,
Aviv
Regards,
Aviv
‎12-13-2017 03:26 PM
Hi Son;
Here is the datasheet for the ExtremeWireless™ WiNG VX 9000 Controller
Thanks Robert, but I want the information of the Virtual controller by using an AP?
‎12-13-2017 02:40 PM
You can find most information in the data sheet.
The limit is maybe not at the controller, but at the RF Domain.
For example a AP can just "control" 128 per RF Domain. With the AP84xx, AP85xx and AP7632 the limit is extend to 256 APs.
To you would build one big network or manage several locations?
