Max concurrent client connections per WiNG AP?
Son_Nguyen2
New Contributor III
Hi everyone,
Could someone let me know the max concurrent client connections per radio and per AP of WiNG APs like 76xx, 75xx, 8533, 8432?
What are parameters affect to this? And how to estimate the max number in real operation?
Thanks so much.
9 REPLIES 9
Hi Ondrej,
If so, what is the parameter affect mostly to this? Is there a formula to estimate the max concurrent connection by data rate per connnection?
This is very important number which all customer want to know about a wifi AP. They want a real number, not theory.
Thanks.
JESUS_REYES_DIA
This value Is relative AND theoric . By radio i recomend no More than 50% of capacity by radio. Example : ap7522 has 800mbps then 50% Is 400 MB . You assure 10 MB by user then you has only 40 users like limit.
Hi Jesus,
By this theory, if i assure 2 MB per user, i will have max 200 user connect concurrently?
Ronald_Dvorak
Honored Contributor
You should be able to find that information in the datasheet of the AP...
http://www.extremenetworks.com/extremewireless-wing/
i.e AP7632 datasheet
Concurrent Users = 256 per radio
But about both 2 radios also per AP? And other model?
