Not mesh connection Mesh between AP 8432 and AP7632
Alan_Phan
Dear Team,
Please help me resolve this issue:
I try to setup Mesh between two APs. One is connected with Ethernet (AP 8432)and one not(AP 7632).
. Would you please give me some idea can fix it.
many thanks,
Alan
1 ACCEPTED SOLUTION
Christoph_S
Hello Alan,
Recommended changes:
Change control vlan in meshpoint on both so something like vlan 99
Change antenna mode from 1x1 to 2x2 again on both as an override
Critical change:
Add country code to your rf-domain or else the radios will not broadcast:
rf-domain default
no country-code
use nsight-policy default
If issue is not resolved at this point I would recommend you contact GTAC to open a case.
Thank you,
Chris
Christoph S.
6 REPLIES 6
Alan_Phan
Great.... Done
Thanks for support, Chris
Christoph_S
Hello Alan,
Critical change:
rf-domain default
no country-code
Thank you,
Chris
Christoph S.
Alan_Phan
Hello Chris,
I followed as your document but it not ok. I do not know why, could you reference log the attack file below
https://1drv.ms/f/s!AjaVi4rajm-PiDAqM7XROYnDV9TR
Kindly help to check
Thanks,
Alan
Christoph_S
Hello Alan,
It all depends on your deployment, if you are setting up these 2 APs to only bridge 2 sites wirelessly then you don't really need a virtual controller; however, if you have multiple APs you'd like the AP8432 to adopt, then you can turn it into a virtual controller. Make sure you configure the AnyAP profile for heterogeneous AP adoption.
In other words, a VC is not a must for meshconnex to work, but you can configure this setting should you like all APs adopted by VC.
https://gtacknowledge.extremenetworks.com/articles/Q_A/Unable-to-adopt-heterogeneous-different-APs-by-my-WiNG-virtual-controller
Thank you,
Chris
Christoph S.
