RFS4000 running 5.8.1.0-012R - AP6522 running in bridge mode
Jeremy-Bullfrog
Further to a previous post on this forum, trying to get an AP into bridge mode, I've acquired an AP6522 which is supposed to support bridge mode, however under RF mode I can only select 2.4Ghz-wlan,5Ghz-wlan or sensor. I should be able to select bridge, what am I missing here?
It's successfully adopted to an RFS4000 running version 5.8.1.0-012R.
Thanks
Jeremy
1 ACCEPTED SOLUTION
Daren_E
Hi Jeremy,
Assuming you mean client bridge mode.
Yes the AP6522 supports client bridge mode.
You did not specify if you checked both radio1 and 2.
I would suggest if possible to be on the newest version of 5.8.x code which is 5.8.9.6
See some articles below on Mesh and client bridge setup for WING:
https://extreme-networks.my.site.com/ExtrArticleDetail?an=000101025
https://extreme-networks.my.site.com/ExtrArticleDetail?an=000082884
6 REPLIES 6
Hi Jeremy,
Version 5.8.6.7 is an ok version to be on.
The main concern was possible bug causing AP not to enable radio bridge mode.
Glad the solution is working.
Christoph_S
Hello @Jeremy-Bullfrog,
What exactly are you trying to achieve?
We have bridging mode tunnel on the WLAN, bridging as in meshing (wireless bridge between 2 APs), and client bridge. Which bridge function are you referring to?
BR,
Christoph S.
