Serious problem with MESH on wing ap410, 7.5.1.1-020R
‎01-25-2021 04:13 PM
Hello, maybe someone can share experience or give advice about MESH configuraion.
I have implemented mesh for warehouse, three alleys, 6 root AP’s with panel antennas and two mobile AP’s on the gantrys.
The problem is - after 4 days working, both mobile APs disconnected from mesh and unadopted from controller. After some time AP’s back and working for some time then again, both disapeared.
my config is:
meshpoint-qos-policy MESH
meshpoint MESH
meshid 1
beacon-format mesh-point
control-vlan 1
allowed-vlans 1-4094
use meshpoint-qos-policy MESH
security-mode psk
wpa2 psk 0 key
root
profile ap410 mesh-root
no autoinstall configuration
no autoinstall firmware
interface radio1
shutdown
interface radio2
channel 44ww
rts-threshold 1
meshpoint MESH bss 1
antenna-gain 6.0
no dynamic-chain-selection
interface radio3
shutdown
interface bluetooth1
shutdown
mode le-sensor
interface ge1
interface ge2
interface pppoe1
use firewall-policy default
rf-domain-manager capable
rf-domain-manager priority 1
controller vlan 1
service pm sys-restart
router ospf
meshpoint-device MESH
root
path-method uniform
adoption-mode controller
profile ap410 non-root-MESH
interface radio1
shutdown
interface radio2
channel 44ww
rts-threshold 1
antenna-gain 6.0
interface radio3
shutdown
shutdown
mode le-sensor
interface ge1
interface ge2
interface pppoe1
router ospf
no root
path-method mobile-snr-leaf
rf-domain default
timezone CET
country-code pl
ad-wips-wireless-mitigation disable
ad-wips-wired-mitigation disable
ap410 48-9B-D5-FE-1B-F2
use profile mesh-root
use rf-domain default
hostname CAP-AK-FE1BF2
interface radio1
ldpc
interface radio2
ldpc
interface vlan1
description "Virtual Interface for LAN by Wizard"
ip address 172.28.0.213/24
ip address zeroconf secondary
ip dhcp client request options all
ntp server 172.28.0.2
virtual-controller
rf-domain-manager priority 255
no adoption-mode
ap410 48-9B-D5-FE-2C-18
hostname ap410-FE2C18
interface vlan1
ip address 172.28.0.211/24
ap410 48-9B-D5-FE-2C-54
use profile non-root-MESH
hostname ap410-FE2C54
interface vlan1
ip address 172.28.0.215/24
events from controller:
2021-01-24 00:54:21 ap410-FE2D0E MESH MESHPOINT_LOOP_PREVENT_OFF Meshpoint loop prevention off (port ALL), all wired traffic is allowed
2021-01-24 00:54:21 ap410-FE2D0E MESH MESHPOINT_UP Meshpoint 'MESH' detected up
2021-01-24 00:54:12 ap410-FE2C54 MESH MESHPOINT_LOOP_PREVENT_OFF Meshpoint loop prevention off (port ALL), all wired traffic is allowed
2021-01-24 00:54:12 ap410-FE2C54 MESH MESHPOINT_UP Meshpoint 'MESH' detected up
2021-01-24 00:54:01 ap410-FE2C54 SYSTEM CONFIG_REVISION Configuration revision updated to 37 from 38
2021-01-24 00:54:01 ap410-FE2C54 SYSTEM CONFIG_COMMIT Configuration commit by user 'cfgd' (update own config) from '127.0.0.1'
2021-01-24 00:54:01 ap410-FE2C54 DEVICE ADOPTED_TO_CONTROLLER Joined successfully with controller 'CAP-AK-FE1BF2'(55.FE.1B.F2)
2021-01-24 00:54:02 CAP-AK-FE1BF2 DEVICE DEVICE_AUTOUP_NO_NEED AUTOUPGRADE: ap410 mac 48-9B-D5-FE-2C-54 ver 7.5.1.1-020R Autoupgrade not required or not available
2021-01-24 00:54:02 CAP-AK-FE1BF2 DEVICE ADOPTED Device('ap410-FE2C54'/'ap410'/48-9B-D5-FE-2C-54) at rf-domain:'default' adopted and configured. Radios: Count=3, Bss: 48-9B-D5-F3-6C-40|48-9B-D5-F3-6C-50|48-9B-D5-FE-2C-59|
2021-01-24 00:54:00 ap410-FE2D0E SYSTEM CONFIG_REVISION Configuration revision updated to 37 from 38
2021-01-24 00:54:00 ap410-FE2D0E SYSTEM CONFIG_COMMIT Configuration commit by user 'cfgd' (update own config) from '127.0.0.1'
2021-01-24 00:54:00 ap410-FE2D0E DEVICE ADOPTED_TO_CONTROLLER Joined successfully with controller 'CAP-AK-FE1BF2'(55.FE.1B.F2)
2021-01-24 00:54:00 CAP-AK-FE1BF2 DEVICE DEVICE_AUTOUP_NO_NEED AUTOUPGRADE: ap410 mac 48-9B-D5-FE-2D-0E ver 7.5.1.1-020R Autoupgrade not required or not available
2021-01-24 00:54:00 CAP-AK-FE1BF2 DEVICE ADOPTED Device('ap410-FE2D0E'/'ap410'/48-9B-D5-FE-2D-0E) at rf-domain:'default' adopted and configured. Radios: Count=3, Bss: 48-9B-D5-F3-70-20|48-9B-D5-F3-70-30|48-9B-D5-FE-2D-13|
2021-01-23 12:07:00 CAP-AK-FE1BF2 DEVICE OFFLINE Device 48-9B-D5-FE-2D-0E(ap410-FE2D0E) is offline, last seen:10 minutes ago on switchport -
2021-01-23 12:07:00 CAP-AK-FE1BF2 DEVICE OFFLINE Device 48-9B-D5-FE-2C-54(ap410-FE2C54) is offline, last seen:10 minutes ago on switchport -
2021-01-23 11:56:56 CAP-AK-FE1BF2 DEVICE UNADOPTED Device('ap410-FE2D0E'/'ap410'/48-9B-D5-FE-2D-0E) at rf-domain:'default' unadopted. Radios: Count=3, Bss: 48-9B-D5-F3-70-20|48-9B-D5-F3-70-30|48-9B-D5-FE-2D-13|
2021-01-23 11:56:46 CAP-AK-FE1BF2 DEVICE UNADOPTED Device('ap410-FE2C54'/'ap410'/48-9B-D5-FE-2C-54) at rf-domain:'default' unadopted. Radios: Count=3, Bss: 48-9B-D5-F3-6C-40|48-9B-D5-F3-6C-50|48-9B-D5-FE-2C-59|
There was site survey made - signal coverage was ok.
any ideas? Why both ap at the same time disconnects ?
regards,
Tomek
‎02-05-2021 12:53 PM
Customer expecting fast path change after one root ap failure, less than 1-2 sec. For now it is 2-14 sec.
Also sometimes when mobile ap changing root, there is 1-2 sec outage, we expected fast roaming less than 50ms.
Problem is that mobile gantry, connected via MESH mobile AP is connection sensive. It communicate to control device via udp multicast messages. If there is no communication when it requesting orders then it stops.
regards,
Tomek
‎02-04-2021 01:59 PM
Hi Tomasz
Failure scenarios depend of the check/verification timeout. What was your expectation time ?
‎02-01-2021 03:12 PM
Valter,
after downgrade it looks more stable but i’ll give it some time to check if it is permanent. Last time it was working 4 days till crash.
Have you tested failure scenarios eg. disabling radio on root AP mobile is attached to ?
In mine enviromene it last 2-9 sec to reattach.
could you share your config ?
regards,
Tomek
‎02-01-2021 08:57 AM
Hello Valter, thank you for downgrade sugestion. I had 7.5.1.1 then 7.5.1.3.
It is very unstable and unpredictable. Root ap losing neighbours without reason.
Mobile APs losing connections and doesn't attach to mesh.
I’ll try downgrade and let you know.
regards,
Tomek
