Hello Hakim,
You can chose from
CLI or
GUI method creating the captive portal.
If you wish, you can use
LDAP as authentication source also.
The redirection is more difficult here as you'd need to create a tunnel for this.
Otherwise I am afraid this is not possible. Would you tell me little more about the design?
Regards,
Ondrej
