The VX9000 is supplied into downloadable image images
image 1) VX9000-5.9.1.4-004R.img
This is the full image contains all software images for all support access point
image 2)VX9000-LEAN-5.9.1.4-004R.img
The lean image has had the AP software images removed to reduce the size of the software build
To confirm the software images installed
please use the following command
show device-image versions
This will list all software versions installed
AP's will also adopt even if the there is a software mismatch.
show adoption status
will tell you if the aps have been adopted, if there is a software mismatch this will show here.
Finally, the VX9000 does not automatically update the firmware
to manually update firmware please use
device-upgrade all
