‎03-29-2014 04:59 PM
2 weeks ago
Dropping 1 to 2 pings during a roam is fairly common on the Extreme Networks WM3700 controller, but you can minimize it by tuning your wireless settings. Enabling fast roaming features like 802.11r or Opportunistic Key Caching (OKC), optimizing channel overlap to around 15–20%, and adjusting AP transmit power levels will help clients transition smoothly between access points without persistent connection drops.
3 weeks ago
A loss of one or two pings during a roam can happen while the client is switching between APs, especially with older clients or if the AP coverage overlap isn’t ideal. I’d check the signal level where the client starts roaming and make sure adjacent APs have enough coverage overlap. It would also be worth testing with a couple of different client devices, since the client itself usually plays a big role in deciding when to roam. If the drops consistently happen in the same areas, I’d check the RF/channel plan and AP power levels before changing anything on the controller.
‎04-01-2014 02:56 PM
‎03-31-2014 03:10 PM
