MAC Address Block on ERS 4950
Hello, Is it possible to block specific MACAddresses on ports in ERS 4950GTS-PWR ?How can we do that?Thank yu.
Good morning I have XMC 8.5.7.28 we have leveraged our technical support department to use the XMC end system page with certain capabilities, for example changing the device group computers the manage. In recent versions of XMC they introduce the "cl...
I've enabled in the global settings google authenticator.When I creat a new user to access XIQ, this user can login with the username and password. The user does not need to use the authenticator.Did I adjust the right setting?What I want is th...
Hi,Trying to setting up a radius access to CLI on VOSS devices, LDAP/Bind authentication process on an AD works fine when using an attribute without domain name extension, e.g. firstname.lastname (here "uid" for user search attribute, with entry like...
Oracle released their CPU Advisories for Jan 2022https://www.oracle.com/security-alerts/cpujan2022.htmlBesides others there are several CVEs for Java and Mysql listed.I would like to know if and how XMC is affected
| User | Count |
| 7 | |
| 5 | |
| 2 | |
| 2 | |
| 2 |
