Problems upgrading firmware via XMC
Pedro_Rocha
New Contributor III
Hi guys,
I'm having some dificulties upgrading x460 switches via XMC. The device i'm trying to upgrade is a single switch (not stack) but i get an error message saying that "all device in the stack must be using the same active partition. correct and repeat firmware download".
Do you have any idea of what could be the problem?
Thanks!
3 REPLIES 3
Ryan_Yacobucci
Hello,
I do not know what the problem could be. I would suggest a ticket with GTAC and we can enable debug to see what's going wrong.
Thanks
-Ryan
Pedro_Rocha
New Contributor III
Hi @Ryan Yacobucci,
This is happening in multiple switches. But the one that we are testing, was never a part of a stack.
ESSV_GabSI.1 # sh switch
SysName: XXXXXXX
SysLocation:
SysContact: XXXXXXX
System MAC: 00:04:96:9E:6F:E5
System Type: X460G2-16mp-32p
SysHealth check: Enabled (Normal)
Recovery Mode: All
System Watchdog: Enabled
Current Time: Fri Dec 10 12:11:27 2021
Timezone: [Auto DST Disabled] GMT Offset: 0 minutes, name is UTC.
Boot Time: Wed Nov 24 18:15:55 2021
Boot Count: 3
Next Reboot: None scheduled
System UpTime: 15 days 17 hours 55 minutes 31 seconds
Current State: OPERATIONAL
Image Selected: primary
Image Booted: primary
Primary ver: 30.5.1.15
Secondary ver: 30.5.1.15
Config Selected: primary.cfg
Config Booted: primary.cfg
Config Automatic: NONE (Disabled)
primary.cfg Created by ExtremeXOS version 30.5.1.15
605129 bytes saved on Fri Dec 10 11:44:32 2021
LAA MAC: Locally Administered MAC Address Disabled
ESSV_GabSI.2 #
ESSV_GabSI.3 # sh stacking
Stack Topology is a Daisy-Chain
This node is not in an Active Topology
Node MAC Address Slot Stack State Role Flags
ESSV_GabSI.4 # sh stacking
stacking stacking information
stacking-support stacking-support information
ESSV_GabSI.4 # sh stacking-support
Stack Available Ports
Port Native Alternate Configured Current
1 Yes 51 Native N/A
2 Yes 52 Native N/A
stacking-support: Disabled Disabled
auto-discovery: Enabled Enabled
Flags: * - Current stack port selection
ESSV_GabSI.5 #
Ryan_Yacobucci
Hello,
Was this switch part of a stack at one point?
Is stacking enabled?
What do you see with the command "Show Switch"?
Does XMC show the device family as an Exos Stack?
Thanks
-Ryan
