11-13-2020 11:44 AM
XCC: With RF Policy we can configure the baseline for channel selection and power range. Using this RF profile with a device group in the site configuration it will be activated on the APs in this device group. Having the requirement to fix the used channel of an AP - f.e. in case of DFS areas or specific usecases - but need to have still auto power enabled, this will not work. Using a overwrite of RF configuration on AP with a static channel the power settings will be static as well.
The requirement is to use auto power function with a static channel selection on a per AP basis.
EWC & XIQ can do that...
br
Volker
