SamPirok
If attempting to start an AP5010 (GA expected August 2022) with an HP JY728A console cable connected, the AP will fail to start.
Software Affected
All supported IQ Engine (IQE) and WiNG-OS releases
Symptoms
The AP will not successfully boot into the operating system. The console readout will be as follows:
BTRM
V3.2
L1CD
MMUI
DATA
ZBBS
MAIN
SNOR
OTP?
OTPP
USBT
FAIL
Workaround
Disconnect the AP5010 from PoE or power adapter and disconnect the HP JY728A console cable. Reconnect PoE or power and allow the AP to boot. Reconnect the HP JY728A console cable.
Solution
Extreme recommends customers to use Extreme Micro USB console cable.
Part Number: ACC-WIFI-MICRO-USB
For more details, please see the full field notice here.
