800-series console problem / factory default
‎09-17-2015 04:46 PM
how can we manage an 800-switch (08G20G4-24) - we have forgot the configured IP-address and cannot manage via serial-console (no output on the terminal- maybe the serial port is disabled). how can we set the switch to factory-default (IP: 192.168.10.1) and how can we enable the serial-console?
the switch bootet and work fine (all port are o.k. and data were transfered) - here are the LED-status: PWR-LED lits green / CPU-LED does´nt lit / RPS-LED does´nt lit / FAN-LED does´nt lit
thanks a lot!
thanks a lot!
11 REPLIES 11
‎09-18-2015 02:18 PM
It looks like you have got a switch with a defective COM port and LED. Device needs to be replaced. To generate an RMA go to https://extranet.extremenetworks.com/mysupport/ocm/pages/rma.aspx and fill out the form with shipping and product information and we will take care of it for you.
‎09-18-2015 01:53 PM
I think there are no discovery protocols running on the 800...
‎09-18-2015 01:50 PM
Are there any discovery protocols running on this switch (CDP, LLDP, etc.)? If so, you may be able to find an IP address from another connected device or via packet capture.
‎09-18-2015 01:18 PM
Thats the really problem: the device still forwarding data traffic fine - but we cannot reach via console (CPU-LED does´nt lit) and have forgot the IP-address...
‎09-18-2015 11:44 AM
The serial port interface is enabled by default. You mentioned that the status of the CPU LED is off. The CPU LED should be solid green if it were operating correctly. Is the device still forwarding data traffic? You need access via console to reset the configuration to factory defaults. See document https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-recover-password-of-800-Series-swit... for additional information.
