LACP/LAG with 'switches in between' (not true 2-Tier)?
Frank
Contributor II
I'm drawing a blank as to "do I do this right, or what do I do wrong?". If you look at the following:
Note that there is no ISC/MLAG between the two 460s.
Coworker and I are debating if the two ports on the Cisco stack need to be put in a LACP/channel-group or not. Neither of us has good enough arguments or detailed enough knowledge as to what exactly is happening, so if anyone could help, that'd be awesome!
- Is the above design reasonable/unreasonable/plain wrong?
- Do the Cisco ports need to be configured as two regular normal trunked/tagged ports, or do they need to be configured as channel/lacp/shared ports?
- or would they only need to be lacp ports if (and only if) the 460s would get an ISC/MLAG between them?
At this point I'm not sure if I could be trusted to connect two tin cans with a string!
Thanks for you help,
Frank
19 REPLIES 19
The Cisco port configuration was exactly what we were debating 🙂
And yes, this does help immensely (together with Stephane's comment below)
Hey Frank
I guess I am confused on how the two ports on the cisco is configured. The connections from the cisco would be either a LAG, where the switch determines which link to send the traffic to, or in an active/passive design using a redundant port configuration. If you can use the redundant port I think that would work here if it is a LAG I don't think that would work as you don't have MLAG on the 460s.
Does that help?
P
Single point failure would still be covered in above diagram - if let's say the connection cisco->460-2 fails, packets would still be able to get to everywhere via 460-1 -> 8800 -> somewhere-including-460-2
I understand that an mlag between the 460s would give me multi-point failure resilience plus bandwidth (which, however, in most of our cases is negligible)
Background: the 460s are typically customer-access-port edge switches in a multi-tenant datacenter. While most customers are happy with either one non-redundant connection, or two connections that go into two of their firewalls (active/passive) where I don't have to worry about lag/lacp, there is the occasional scenario as above. Due to the "nobody needed it before" nature, we haven't MLAGed those 460s. "Yet (tm)" 🙂
Frank
Contributor II
I did configure ELRP on the respective VLAN on the 460s, hoping that would be sufficient?
(excluding the 460-to-8800 ports so it should only block the ports to the Cisco - because a lot of other VLANs go from the 460 to the 8800)
OscarK
Only when you make the X460 do MLAG you can add the ports in a channel group.
If the X460 do not do MLAG you need to have a redundancy protocol to prevent loops.
You can however make the ports a trunk as you will put tagged frames on it.
