06-02-2020 01:34 PM
I am starting to look at ANSIBLE as a COVID19 learning project.
Curious if anyone has built anything with ANSIBLE for VSP/VOSS management. Willing to share you work and experience? Thanks
Full disclosure, as my titles reads I do work at Extreme. This is purely for self education.
Solved! Go to Solution.
06-02-2020 02:17 PM
Paul,
There is basic support for VSP/VOSS in Ansible with ‘network_cli’ plugin(connection type) and modules voss_command, voss_config, voss_facts.
https://github.com/extremenetworks/ansible-extreme has some details and documentation links.
Note: The document links in the README of the above repository is broken. I have created a PR(https://github.com/extremenetworks/ansible-extreme/pull/23) to fix them.
Ujwal
2 weeks ago - last edited 2 weeks ago
Ansible is an excellent choice for a learning project, especially for automation tasks in IT infrastructure. While I haven’t personally worked on VSP/VOSS management using Ansible, about the platform is well-suited for such tasks given its ability to automate network configurations and deployments.
06-07-2021 10:50 AM
Hm, nice approach. Interested in what other have to say about it!
01-05-2021 08:37 PM
Hi Paul,
I have created and tested some Ansible playbooks with VOSS and EXOS using GNS3.
I can share some is you are interested.
Best regards!
Ricardo
06-02-2020 03:37 PM
thanks
I was more curious if someone has built some scripts or a playbook so I don’t have to write something from scratch.
