Support for running XIQ software or appliances on Nutanix AHV hypervisor
wprather
I'm a sales engineer on the data center side and ran into this today.  Had to do a little research...
Officially, it appears Extreme Networks doesn't support running their appliances on Nutanix AHV.  AHV is actually a derivative of Redhat KVM, so if it will run on KVM (usually a QCOW image), it will likely run on AHV, or can be configured to.  It is *supported* to run the appliances on ESX or HyperV or KVM, I believe.
My question is - If I just build a new VM on AHV with the right specs, running a compatible linux distro, can't I just install the XIQ SiteEngine and XIQ Controller apps on them and treat them well?  Is this supported?  Is the functionality the same?
Thank you for any help.
-wes
1 ACCEPTED SOLUTION
Hi.
See the ExtremeCloud™ IQ Site Engine, ExtremeControl®, and ExtremeAnalytics®Virtual Engine Installation Guide. The most recent version of the document can be found at the ExtremeCloud IQ Site Engine Documentation site. Select Installation Guide > Virtual Engine Installation Guide at the top of the page.
Sincerely yours
Regards Zdeněk Pala
5 REPLIES 5
Zdeněk_Pala
ExtremCloud IQ - Site Engine & ExtremeControl & Extreme Analytics are Nutanix certified since version 24.10!
Sincerely yours
Regards Zdeněk Pala
