Adding on X670G2 to an existing OSPF network
  • Problem
  • Updated 2 years ago
  • Solved
The OSPF network is a X460-24t and two cisco routers. all configured in the same area.
The fimrware of the X460 and the X670 is  16.1.2.14.
But for some reason the X670 is not learning or distribute any route.
How can I troubleshoot this ?
Photo of Johan Hendrikx
Johan Hendrikx
  • 3,804 Points 3k badge 2x thumb
Posted 2 years ago
Photo of OscarK
OscarK, ESE
  • 7,912 Points 5k badge 2x thumb
Hello Johan, is neighborship established ? Are area's configured right, is the mtu the same between the neighbors ? Is your license sufficient ? (some edge licenses cannot be DR/BDR).
Johan Hendrikx
Oscar, neighborship is established. The license is oke (core). MTU could be the issue.
I wil check this
Photo of Parthiban V
Parthiban V, Employee
  • 618 Points 500 badge 2x thumb
Hi Johan, If neighborship is established then MTU should not be the problem. What type of route is not getting installed ? Do you have any import policies configured ?
Johan Hendrikx
I don't use policies. OSPF config is very basic.
configure ospf routerid <router-id>
enable ospf
enable ospf export static cost 2 type ase-type-1
configure ospf add vlan <vlanx> area 0.0.0.0
vlanx is not learned form the other neighbor and is not distibuted to the others
Photo of Ariyakudi Srinivas, Muthuraman
Ariyakudi Srinivas, Muthuraman, Employee
  • 994 Points 500 badge 2x thumb
From the X670's perspective, check if all the subnets that needs to be advertised are all active and OSPF ready.
Johan Hendrikx
subnet is active an ospf ready
Photo of OscarK
OscarK, ESE
To export all IP vlans with ospf use command:
enable ospf export direct cost 2 type ase-type-1
Johan Hendrikx
no change.
Photo of OscarK
OscarK, ESE
Can you post show ospf interfaces ?
Johan Hendrikx
GIDAT      144.2.144.249  /21 0.0.0.0         -rif---       2/A ODR       4
GIDTP      10.2.120.254   /24 0.0.0.0         -rif---       4/A DR        0
GITEST     10.2.128.254   /24 0.0.0.0         -rif---       2/A DR        0
GIVOIP1    10.2.161.254   /24 0.0.0.0         -rif---       4/A DR        0
Photo of Henrique
Henrique, Employee
  • 10,342 Points 10k badge 2x thumb
Hi Johan, could you please share the output for "show ospf interfaces" command?
Thanks
Photo of Bill Stritzinger
Bill Stritzinger, Alum
  • 6,036 Points 5k badge 2x thumb
Johan,
Please check the configuration for OSPF "hello timers" and make sure they are the same for both the Extreme and Cisco.  If they are different you will not have any communications.
Bill
Johan Hendrikx
The timers should be oke , because the x460 receive all the routes
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 13,720 Points 10k badge 2x thumb
Hi Johan,
if OSPF adjacencies are formed, but no routes seen using the link, the problem might be a point-to-point interface configuration on only one of the routers. Since you did not specify point-to-point in the OSPF config you showed us, I would suggest you check if the Cisco is using a point-to-point interface to the Extreme X670G2.
Erik
Hi Johan,
   From your "show ospf interface" output i could see you have configured a broadcast network through the vlan "GIDAT".
Please provide the following details for both x460 and x670 for the further debugging.
show ospf interface
show ospf interface detail
show ospf neighbor
show configuration ospf
Johan Hendrikx
how would you like the output ?
(Edited)
Johan Hendrikx
Output switch X460:
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2016.12.14 10:35:02 =~=~=~=~=~=~=~=~=~=~=~=
telnet session telnet0 on /dev/ptyb0
Connected to Core Switch at Audax Gilze CS-F01-1
Closed system, authorised users only !!
Session will be logged.
login: admin
password:
ExtremeXOS
Copyright (C) 1996-2015 Extreme Networks. All rights reserved.
This product is protected by one or more US patents listed at http://www.extremenetworks.com/patents along with their foreign counterparts.
Press the <tab> or '?' key at any time for completions.
Remember to save your configuration changes.
CS-F01-1.1 # sh ospf in
CS-F01-1.1 # sh ospf interfaces
 VLAN      IP Address         AREA ID         Flags      Cost State   Neighbors
GI-AP      10.2.114.253   /24 0.0.0.0         -rif---       4/A DR        0
GI-MGMT    10.2.112.253   /24 0.0.0.0         -rif---       4/A DR        0
GIBEHEER   144.2.112.253  /24 0.0.0.0         -rif---       4/A DR        0
GIDAT      144.2.144.253  /21 0.0.0.0         -rif---       4/A ODR       4
gidat1     10.2.144.253   /21 0.0.0.0         -rif---       4/A DR        0
GINFS      144.2.166.253  /24 0.0.0.0         -rif---       4/A BDR       1
GIVIDEO    10.2.38.253    /24 0.0.0.0         -rif---       4/A DR        0
Flags:  b - BFD protection configured, D - Duplicate address detected on VLAN,
        f - Interface Forwarding Enabled, i - Interface OSPF Enabled,
        n - Multinetted VLAN, p - Passive Interface, r - Router OSPF Enable,
        T - Tentative address.
Cost:   A - Automatic Cost, C - Configured Cost.
Total number of interfaces: 17
CS-F01-1.2 #
CS-F01-1.2 # sh ospf interfaces det
Interface(rif1000009): 10.2.114.253/24 Vlan: GI-AP OSPF: ENABLED Router: ENABLED
AreaId: 0.0.0.0  RtId: 10.2.144.253  Link Type: broadcast(auto)  Passive: No
Cost: 4/A  Priority: 1  Transit Delay: 1  DAD State:Valid
Hello Interval: 10s  Rtr Dead Time: 40s  Retransmit Interval: 5s
Wait Timer: 40s(auto)
Authentication: NONE
State: DR   Number of events: 1
DR RtId: 10.2.144.253  DR IP addr: 10.2.114.253  BDR IP addr: 0.0.0.0
Num Neighbor State Change to FULL : 1
BFD Protection: Off
Press <SPACE> to continue or <Q> to quit:
Neighbors:
Interface(rif1000006): 10.2.112.253/24 Vlan: GI-MGMT OSPF: ENABLED Router: ENABLED
DR RtId: 10.2.144.253  DR IP addr: 10.2.112.253  BDR IP addr: 0.0.0.0
Num Neighbor State Change to FULL : 0
BFD Protection: Off
Neighbors:
Interface(rif1000011): 144.2.112.253/24 Vlan: GIBEHEER OSPF: ENABLED Router: ENABLED
Press <SPACE> to continue or <Q> to quit:State: DR   Number of events: 1
DR RtId: 10.2.144.253  DR IP addr: 144.2.112.253  BDR IP addr: 0.0.0.0
BFD Protection: Off
Neighbors:
Interface(rif1000012): 144.2.144.253/21 Vlan: GIDAT OSPF: ENABLED Router: ENABLED
State: ODR   Number of events: 1
DR RtId: 192.168.178.63  DR IP addr: 144.2.144.251  BDR IP addr: 144.2.144.250
Num Neighbor State Change to FULL : 1381
BFD Protection: Off
Neighbors:
   RtrId: 192.168.178.63  IpAddr: 144.2.144.251  Pri: 10  Type: Auto
   State: FULL  Dr: 144.2.144.251  BDR: 144.2.144.250  Dead Time: 00:00:00:01
   Options (0x52):  Opaque LSA: Yes
   BFD Session State: None
   RtrId: 10.2.144.254  IpAddr: 144.2.144.249  Pri: 1  Type: Auto
   State: 2WAY  Dr: 144.2.144.251  BDR: 144.2.144.250  Dead Time: 00:00:00:05
   Options (0x0):  Opaque LSA: No
   RtrId: 144.2.144.254  IpAddr: 144.2.144.254  Pri: 1  Type: Auto
   State: 2WAY  Dr: 144.2.144.251  BDR: 144.2.144.250  Dead Time: 00:00:00:02
   Options (0x42):  Opaque LSA: Yes
   RtrId: 10.216.167.31  IpAddr: 144.2.144.250  Pri: 10  Type: Auto
   State: FULL  Dr: 144.2.144.251  BDR: 144.2.144.250  Dead Time: 00:00:00:09
Interface(rif1000013): 10.2.144.253/21 Vlan: gidat1 OSPF: ENABLED Router: ENABLED
DR RtId: 10.2.144.253  DR IP addr: 10.2.144.253  BDR IP addr: 0.0.0.0
BFD Protection: Off
Neighbors:
Interface(rif1000023): 144.2.166.253/24 Vlan: GINFS OSPF: ENABLED Router: ENABLED
Press <SPACE> to continue or <Q> to quit:Cost: 4/A  Priority: 1  Transit Delay: 1  DAD State:Valid
State: BDR   Number of events: 1
DR RtId: 144.2.144.254  DR IP addr: 144.2.166.254  BDR IP addr: 144.2.166.253
Num Neighbor State Change to FULL : 119
BFD Protection: Off
Neighbors:
   RtrId: 144.2.144.254  IpAddr: 144.2.166.254  Pri: 1  Type: Auto
   State: FULL  Dr: 144.2.166.254  BDR: 144.2.166.253  Dead Time: 00:00:00:06
Interface(rif1000034): 10.2.38.253/24 Vlan: GIVIDEO OSPF: ENABLED Router: ENABLED
DR RtId: 10.2.144.253  DR IP addr: 10.2.38.253  BDR IP addr: 0.0.0.0
BFD Protection: Off
Neighbors:
Press <SPACE> to continue or <Q> to quit:CS-F01-1.3 #
CS-F01-1.3 # sh ospf interfaces detneig
CS-F01-1.3 # sh ospf neighbor
Neighbor ID     Pri State              Up/Dead Time             Address         Interface
          BFD Session State
192.168.178.63   10 FULL      /DR      02:05:22:36/00:00:00:07  144.2.144.251   GIDAT
          None
10.2.144.254      1 2WAY      /DROTHER 05:02:20:52/00:00:00:01  144.2.144.249   GIDAT
          None
144.2.144.254     1 2WAY      /DROTHER 14:00:34:25/00:00:00:08  144.2.144.254   GIDAT
          None
10.216.167.31    10 FULL      /BDR     14:00:34:25/00:00:00:07  144.2.144.250   GIDAT
          None
144.2.144.254     1 FULL      /DR      00:02:34:09/00:00:00:01  144.2.166.254   GINFS
          None
Total number of neighbors: 5 (3 neighbors in Full state)
CS-F01-1.4 # sh conf ospf
# Module ospf configuration.
configure ospf routerid 10.2.144.253
enable ospf
configure ospf add vlan GI-AP area 0.0.0.0
configure ospf add vlan GI-MGMT area 0.0.0.0
configure ospf add vlan GIBEHEER area 0.0.0.0
configure ospf add vlan GIDAT area 0.0.0.0
configure ospf add vlan gidat1 area 0.0.0.0
configure ospf add vlan GINFS area 0.0.0.0
configure ospf add vlan GIVIDEO area 0.0.0.0
CS-F01-1.5 # exit
Johan Hendrikx
Output switch X670
CS-A01-2.1 # sh ospf int
CS-A01-2.1 # sh ospf interfaces
Total number of interfaces: 13
CS-A01-2.2 # sh ospf interfaces detail
Interface(rif1000020): 144.2.144.249/21 Vlan: GIDAT OSPF: ENABLED Router: ENABLED
AreaId: 0.0.0.0  RtId: 10.2.144.254  Link Type: broadcast(auto)  Passive: No
Cost: 2/A  Priority: 1  Transit Delay: 1  DAD State:Valid
DR RtId: 10.216.167.31  DR IP addr: 144.2.144.250  BDR IP addr: 144.2.144.250
BFD Protection: Off
Neighbors:
   State: 2WAY  Dr: 144.2.144.251  BDR: 144.2.144.250  Dead Time: 00:00:00:00
   State: INIT  Dr: 144.2.144.251  BDR: 144.2.144.250  Dead Time: 00:00:00:08
   RtrId: 10.2.144.253  IpAddr: 144.2.144.253  Pri: 1  Type: Auto
   State: 2WAY  Dr: 144.2.144.251  BDR: 144.2.144.250  Dead Time: 00:00:00:09
   State: FULL  Dr: 144.2.144.251  BDR: 144.2.144.250  Dead Time: 00:00:00:05
Interface(rif1000023): 10.2.120.254/24 Vlan: GIDTP OSPF: ENABLED Router: ENABLED
DR RtId: 10.2.144.254  DR IP addr: 10.2.120.254  BDR IP addr: 0.0.0.0
Press <SPACE> to continue or <Q> to quit:Num Neighbor State Change to FULL : 0
BFD Protection: Off
Neighbors:
Interface(rif1000040): 10.2.128.254/24 Vlan: GITEST OSPF: ENABLED Router: ENABLED
DR RtId: 10.2.144.254  DR IP addr: 10.2.128.254  BDR IP addr: 0.0.0.0
BFD Protection: Off
Neighbors:
Interface(rif1000043): 10.2.161.254/24 Vlan: GIVOIP1 OSPF: ENABLED Router: ENABLED
DR RtId: 10.2.144.254  DR IP addr: 10.2.161.254  BDR IP addr: 0.0.0.0
BFD Protection: Off
Neighbors:
CS-A01-2.3 # sh ospf  ne
CS-A01-2.3 # sh ospf neighbor
          BFD Session State
144.2.144.254     1 2WAY      /DROTHER 00:20:47:25/00:00:00:02  144.2.144.254   GIDAT
          None
192.168.178.63   10 INIT      /DR      00:20:47:29/00:00:00:01  144.2.144.251   GIDAT
          None
10.2.144.253      1 2WAY      /DROTHER 00:20:47:32/00:00:00:10  144.2.144.253   GIDAT
          None
10.216.167.31    10 FULL      /BDR     00:20:47:34/00:00:00:07  144.2.144.250   GIDAT
          None
Total number of neighbors: 4 (1 neighbor in Full state)
CS-A01-2.4 # sh conf ospf
configure ospf routerid 10.2.144.254
enable ospf
configure ospf add vlan GIDTP area 0.0.0.0
configure ospf add vlan GITEST area 0.0.0.0
configure ospf add vlan GIVOIP1 area 0.0.0.0
CS-A01-2.5 #
(Edited)
Hi Johan,
    Your output states that you have 5 routers in the OSPF broadcast domain. 192.168.178.63 is your DR and 10.2.144.254 is your BDR and all other 3 routers are DROTHER.
From my observation i could  able to see x670 is in INIT state with the DR (192.168.178.63) and because of that you are not seeing any OSPF routes.
          None
Do the following in your 670.
 1. Ping to the ip interface of DR(RtID: 192.168.178.63) which is configured in the interface which is  connecting 670 to the DR ( i believe it is 144.2.144.251). If ping fails, resolve that. It should be the problem.
Thanks,
Parthiban.V
Johan Hendrikx
I can ping the ipaddress 144.2.144.251
When I look at the OSPF neighbors I see:
192.168.178.63   10 FULL      /DR      02:03:22:31/00:00:00:01  144.2.144.251   GIDAT   None
The routes are learned now. (?). Was the ping the solution ?
No Johan. Just to check the reachability i asked you to try a ping. If Ping fails, for sure OSPF will not establish its neigborship.
 If there is no issue in reachability and OSPF still stays in INIT state we could have went to the next step of debugging.
Johan Hendrikx
After the ping the INIT state is changed in the Full state. So it seems that the problem is spontaneously disappeared.
What would be the next step of debugging?
(Edited)
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 13,566 Points 10k badge 2x thumb
Hi, did you have any log messages? any errors on the link? if you have/had a L1 issue (transceiver, fiber) you might have crc errors preventing the session to be established.
From what I can read in this post, the low layer troubleshooting has not been done. Always start with it.
Johan Hendrikx
there were no CRC errors. We checked that.
Photo of Drew C.
Drew C., Community Manager
  • 40,206 Points 20k badge 2x thumb
Hi Johan,
It's been a while since this topic was updated.  Have you been able to resolve this issue?
Photo of Tripathy, Priya Ranjan
Tripathy, Priya Ranjan, ESE
  • 2,306 Points 2k badge 2x thumb
Hello Johan,
We could see as per t he last post 4 weeks back the OSPF init state was changed to full state already. Hence we believe there is no more issues at present.
Let me tell you here some of the possible troubleshooting which you would always look into when this gets stuck in init state:
Kindly check for the mismatch in any of  the following:
1: router id
2: area id
3: authentication password
4: subnet mask
5: stub area flag
6:hello and dead interval time
But as said earlier always we need to fix the layer 1 issue if any before proceeding further in to deeper analysis.
Please let us know if the suspected issue is resolved so that going forward we can wind off this long pending HUB thread communication
