Extreme AP Configuration
Shane_Quintard
I am trying to setup an AP 3825i to perform a site survey. I am trying to access the CLI to set the config, however, I apparently do not have the default login credentials (admin/admin123 don't work). Does anyone have the correct default login credentials?
8 REPLIES 8
ARABINDA_MOHANT
ok got it
thank u
Ronald_Dvorak
Honored Contributor
You can configure "Maintain client sessions in event of poll failure" via the controller GUI.
ARABINDA_MOHANT
ok, we can configure ap standalone by controller....right
Ronald_Dvorak
Honored Contributor
Yes&No.
There is no standalone mode but as mentioned above you'd configure a controller AP to act like a standalone AP.
That is possible with all controller APs also with the AP3805i.
