Spanning Tree MSTP region and general STP question
  • Question
  • Updated 10 months ago
  • Answered
  • (Edited)
Hi all,
I’m getting ready to decommission some Summit x450e’s and replace them with x460-G2’s. As I’m not very familiar with MTSP or Extreme in general and I’m looking for a little assistance. My plan is to create a trunk between the new 460 stack and one of the old switches and slowly move ports over so things can stay up while I’m doing it.
What I don’t grasp is the MTSP region. Does my new switch stack need to match the MTSP region on the switch I’m going to establish a trunk with? Currently there is no trunking between the old switches though.
As it is now, here is the config on one of the 450’s:
configure mtsp region xxxxxxxxx
configure stpd s0 delete plan default ports all
disable stpd s0 auto-bind vlan default
enable stpd s0 auto-bind plan Default
Coming from the Cisco world, should I lower the STP priority on the new stack before adding it? I’m so confused at this point. Appreciate any assistance.
J.
Photo of John
John
  • 80 Points 75 badge 2x thumb
Posted 10 months ago
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
As long as the STP on the root bridge is lower than the STP priority of another switch you deploy, it will be fine.  I recommend code 23.3.1, it has a STP config similar to Cisco.  Mucher easier to work with.
Photo of John
John
I'll give that a try Jeremy. Appreciate the tip. Can MTSP be left default on the new stack? From what I'm reading that may be a good idea.
Photo of Jeremy
Jeremy, Embassador
I believe you can.  Although you will probably want to turn on edge-safeguard and set your edge ports up correctly etc to stop ports going up and down from causing topology changes.
    configure stpd s0 ports link-type edge 3:33
    configure stpd s0 ports edge-safeguard enable 3:33
    configure stpd s0 ports bpdu-restrict enable 3:33
