WM3700 reset
  • Question
  • Updated 3 years ago
  • Answered
Hello, all!
How can I reset WM3700 without clean license?
Solution like below don't work.
Username: restore
Password: restoreDefaultPassword
Thank you!
Photo of Alexandr P
Alexandr P, Embassador
  • 12,008 Points 10k badge 2x thumb
Posted 3 years ago
Photo of Chad Smith
Chad Smith, Senior Escalation Support Engineer
  • 5,620 Points 5k badge 2x thumb
Official Response
AlexandrP,
That procedure is for software version 4.  If you are on software version 5 try this instead:
Login: reset
Password: FactoryDefault
I added the WiNG 5.X steps to the GTACKnowledge article found here:
How to restore Motorola Wireless Controllers to factory default from the login prompt
(Edited)
