Error 9 The device appears to be in use by another VIQ.
karlc87
Hi Community,
I wanted to register my Aerohive AP230 on ExtremeCloudIQ, but I get the error:
Can you please support me?
Serial number: 02301405161228
Many thanks in advance.
Regards,
Karl
1 ACCEPTED SOLUTION
SamPirok
Community Manager
Hi Karl, thanks for reaching out, that device should now be free to add to your inventory. Is there anything else I can help you with?
27 REPLIES 27
SamPirok
Community Manager
That is correct. If you would like to use the free ExtremeCloud IQ (XIQ) platform, you’ll have to re-register and choose the Connect version of XIQ. Connect is free to use but has a limited feature set. To register for a Connect XIQ instance, you’ll want to go to extremecloudiq.com> Click register here> Fill out the form> wait for the confirmation email and then click the link to set your password> After that you should see the option to use the full feature version of XIQ for a trial period, a place to enter a license if you have one, or the option to use Connect. Choose Connect, rebuild your network policy, then remove your APs from the old XIQ inventory and add them to the Connect inventory.
akin_oezguer
New Contributor III
So I can only do all these steps, if I got a license 😞 right?
SamPirok
Community Manager
You need to apply a new license to the HiveManager before you will be able to leave the page you are on. You will want to contact your sales engineer to partner to purchase a new license.
akin_oezguer
New Contributor III
If I click on Global Settings, nothing happens!
I’ve tried every Browser I got but nothing happens.
Any idea?
SamPirok
Community Manager
You’ll need to add a license to your HiveManager instance before you can leave that page or update the APs. To get a new license you will want to reach out to your sales engineer or partner you purchased your devices from.
After you’ve applied the license, click on this silhouette icon in the top right corner to find Global Settings:
To change the management status back to managed (again after you’ve applied the new license so you see the correct options available), check the box next to the AP> Click Actions> Change Management Status> Manage Devices:
To update the APs firmware you’ll want to check the box next to the AP and click Update Device (which will appear on the screen you took a screen shot of, after you’ve applied a license):
