ExtremeXOS 30.7.3.12 is Now Available
ExtremeXOS 30.7.3.12 has been released!You can view the release notes here. The downloadable files can be found in the Extreme Portal, under Products: ReachNXTX435X440-G2X450-G2X460-G2X465X590X620X670...
Extreme Networks has discovered that mixing different power supply parts in X465, VSP4900, and 5520 models is not supported.The XN-ACPWR-XXXX-FB power supplies require a minimum firmware to use. Backg...
HiWe ran a alternative enhanced stack with 2pcs x695 soft EXOS 31.4.1.5 on the QSFP28 SR4 with MPO connector module and after 2 days at work, on one StackLine we observe rx under the counter. Someone ...
