Resolved! xMC virtual applicance
Can this virtual appliance be configured for snmp? I would like to add our monitoring tools to manage the xMC via SNMP. Thank you
i am trying to generate an SSL cert for our NAC captive portal. I am running a windows certificate authority on our windows server 2012 server. I tried to follow the steps in this link https://extremeportal.force.com/ExtrArticleDetail?an=000078322and...
I want that clients which log in to the guest portal page, don't get the security warning from the browser. Is it sufficient to create a certificate at guestportal topology interface? How should be the CN name and OU name entry in the csr request fil...
We have a x440-G2 stack on which we just enabled identity management. Now in the Extreme Management console, we see the username populated but the "Switch nickname" and display string (in the "Switch Port" column) are no longer shown. In the image ...
Good day Community I'm trying to update our "Endpoint Locations" via exporting the list to a CSV, editing the file and importing the file back into XMC. Everything seems to work fine, except that all Alias data are deleted when importing. I even tr...
| User | Count |
| 106 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
