Resolved! How do I rename or delete an End-System group in NAC
Is there a way to delete or rename an End System group in NAC?
I've made a quick lab on the integration between the Kaspersky security solution and the Extreme Networks solution using the Distributed IPS connect module present on the EMC server. I share with you my lab results and settings. For my lab environm...
We have an Extreme K6 System with a mix of X620 / K6 Switches. We have Advanced XMC / Netsight and we have implemented the analytics via a appliance. The core K6 sends packtes via netflow and a gre tunnel to the analytics appliance. Problem: we se...
I have created an alarm that sends me an email when there is a configuration change for a device between two archives (first screenshot). The problem is that I can not find a variable, to display directly in the mail the change that was made as if I ...
Dear, When I want to download the firmware of switches or even the wireless controller, I see the links to download them. When I want to download the ova files of the nac or xmc, the page stays blank. The same story with the demokit: no link at al...
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
